11-29-2007
The hanks don't hold the sail to the furled headsail. The hanks are used to close a sleeve that wraps around the furled headsail, much like the old sails used on some of the cat-rigged large sailboats, like the Nonsuch IIRC. Given that the sleeve spreads the friction out over a fairly large area, the resistance to hoisting the sail isn't all that great. The hanks themselves are fairly normal sized.
Basically the GaleSail is a headsail with an extension off the luff that wraps around a furled headsail and then is held to the luff with piston hanks, causing the extension to form a tube or sleeve about the furled headsail.
