11-30-2007
Last Grumpy Old Sailor
Everybody that owns something that's got 125VAC distribution (home, sufficiently large boat, etc.) should have one of these: Ground Fault Indicator Tester. (Tho mine doesn't have the button for testing GFCIs.) It'll tell you if hot, neutral and ground are all present and connected to the right points. The one referenced, with the GFCI test button, will test the GFCI circuit, independently of the GFCI's own, built-in tester, as well.
When I bought our house I checked every outlet in the place. Good thing I did, too, being as, for example, the outdoor outlet (had to be that one, of all of 'em, eh?) had ground and neutral reversed. That was an electrocution waiting to happen. (It's got a GFCI outlet there, now.)
Jim
s/v Abracadabra
1976 Pearson P30
