Solar fans - Page 2 - SailNet Community
post #11 of 23 Old 12-01-2007
For what it's worth:
I installed a stainless nicro vent on my van back in 1998. It has never allowed water in, even when driving at 80mph in a heavy rainstorm.
xort is offline
post #12 of 23 Old 12-01-2007
JimsCAL's Avatar
I installed a Nicro day/night vent to replace the passive one in the head when I bought my current boat 18 years ago. Unit has been very reliable - only have had to replace the battery twice in all that time. I do not even notice the very low noise level any more even though it's located right on the other side of a bulkhead where my head is when sleeping. Great product.
JimsCAL is offline
post #13 of 23 Old 01-18-2008
ereuter's Avatar
I'd like to put one of these in my head area as well, but I have a hard plastic headliner in my Pearson 30. Anyone installed one in a situation where the deck and headliner have some space between them? I called Nicro and they said they used to sell a sleeve for this but don't any more.
Eric
ereuter is offline
post #14 of 23 Old 01-18-2008
T37Chef's Avatar
Maybe a little exaggeration
Originally Posted by xort View Post
For what it's worth: even when driving at 80mph in a heavy rainstorm.
Man...that is one fast sailboat you have, Alex would be jealous And if your referring to the boat being trailered...who tows anything at 80 mph...on top of that in a heavy rainstorm.
Shawn
T37Chef is offline
post #15 of 23 Old 01-18-2008
Seasoned Salt
Trekka's Avatar
I don't think that would be a problem. The sleeve of the vent is plenty long enough to cover the space. The only Q would be attaching. If through bolting is not necessary, then, once the hole is cut and vent positioned, you can put screws into the fiberglass. Or if through bolting is necessary you could cut some sections of wood to fill the gap where the bolts would pass through. Just need some small pieces to put the bolts through. Again, the sleeve of the vent is about 3" if I recall.
Trekka is offline
post #16 of 23 Old 01-18-2008
Freesail99's Avatar
The vents come in either 3 or 4 inch. I went with the 4 inch vent figuring, bigger hole equals more air movement.
S/V Scheherazade
Freesail99 is offline
post #17 of 23 Old 01-18-2008
The 4" vents move almost twice the air of the 3" vents, so if ventilation is the goal...go with the 4" vents.
sailingdog is offline
post #18 of 23 Old 01-18-2008
Seasoned Salt
Trekka's Avatar
Agree on 4" vs 3" plus the size of the units is the same, or very nearly. So might as well go for the larger hole.
Btw, for replacement of the "C" sized NiCads in the older models I found them for about $7/pair at Radio trash.
Trekka is offline
post #19 of 23 Old 01-23-2009
lbdavis's Avatar
I want to put two 4" Nicro solar vents in this spring, but it looks like Nicro has stopped making these. I hate to buy something I know I can't replace.
Can anyone confirm/deny that Nicro is no longer making 4" solar vents?
Yes, Dawg, I know this thread is a year old.
S/V Gracie
P303
lbdavis is offline
post #20 of 23 Old 01-23-2009
jimq26's Avatar
I installed one of these 2 years ago & love it!
Specs (see link) call for a 4.5" cut out. It has a switch to turn it on/off, and comes with two fan setups - one for intake, and one to exhaust - works great even under my white winter tarp. I just checked the boat an hour ago, and the fan was exhausting just fine.
eBay Motors: STAINLESS SOLAR POWERED DAY / NIGHT DECK VENTS 13027 (item 330301805355 end time Jan-25-09 18:34:51 PST)
jimq26 is offline
Charging with Solar Power Kevin Jeffrey Gear and Maintenance Articles 0 07-28-2003 09:00 PM
Choosing and Installing Solar Panels Sue & Larry Gear and Maintenance Articles 0 11-06-2000 08:00 PM
