Spraying gelcoat - SailNet Community
post #1 of 2 Old 04-20-2002 Thread Starter
Spraying gelcoat
Does anyone have experience spraying gelcoat for a repair job? I would like to use a small spray gun or airbrush attached to a compressor. Any suggestios as to what will work to spray a pattern of about 1.5"-2" wide. I do not want to use the desposible Prevail type spray units. Thanks for your help.
Ted
replusted is offline
post #2 of 2 Old 04-20-2002
Spraying gelcoat
replusted,
You need quite abit of air press. and volume to spray gel. You can thin it down with styreen. But only a little. Also, gel will not fully kick off (top layer) unless you do one of two things. Either use a sanding agent in the mix, which I would not recomend,it contains wax, and if you ever try to paint over it you will have fisheye problems .
The best way is right after you spray, either spray some PVA(polyvinyl alcolhol) or something that works for me, spray paint from a can, of course if you want a shine and smooth finish, you will have to sand and polish the gel. Very long and hard work.
Hope this helps,
Dave R.
windancer1 is offline
Thin Gelcoat Spot Timm40 Gear & Maintenance 9 06-04-2008 01:40 PM
gelcoat cracks in nonskid fupa Gear & Maintenance 4 09-25-2006 12:51 PM
Please Help! Gelcoat questions...im very confused efiedler Gear & Maintenance 1 04-07-2004 10:16 PM
Gelcoat vs. painted bottom czibailo Racing 2 01-31-2003 02:55 PM
rash decision: applying gelcoat tappers Gear & Maintenance 0 09-18-2002 02:27 PM
