View Poll Results: Best 6 volt golf cart battery for house bank
costco 0 0%
napa 0 0%
interstate 2 28.57%
other 5 71.43%
Multiple Choice Poll. Voters: 7. You may not vote on this poll
Old 12-02-2007
hollyp is on a distinguished road
6 volt golf cart batteries
Hi All, I'm getting ready to buy some 6 volt golf cart batteries to replace my worn out 12 volts. This bank is only used for my electric heads, lectra san, and shower drain. We live aboard so it gets a lot of use. My last bank was replaced about 2 years ago with two group 27 (?) 12 volt deep cycle marine batteries from NAPA. They worked perfectly until about a month ago when they were suddenly drained, probably because I let the water level get too low. I checked them monthly for the first year and they never needed water so I just stopped checking them. They are wired to a 12 volt smart charger that is also just two years old. I figured it's probably not over charging since the water level remained constant for the first year. I could be wrong. I'm wondering if there is any consensus about which battery is the best. I was thinking about costco verses interstate. Also, is there an online resource that can show me how to wire them together? Would I need two or four batteries? Thanks for any help you can offer!
Old 12-02-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
I just bought 4 interstate U2200 for $89.00 each.
S/V Scheherazade
Old 12-02-2007
Two 6V Trojan T105 Golf Cart batteries are going to be significantly higher capacity than a single Group 27 battery, so you really shouldn't need more than two.
As for wiring them together.. wire the positive of one to the load or positive bus for the head's electrical system, then connect the negative of that to the positive of the other battery, and finish by connecting the ground of the second battery to the ground bus of the head's electrical system. Ideally, you should have a panel of some sort with fused switches or breakers for the head, LectraSan and shower sump pump.
Old 12-02-2007
Thanks for the wiring details. I do have a 12 volt panel dedicated to this bank so the wiring should go pretty smoothly. I guess I'll have to buy or borrow a big crimping tool to make the cables. The current bank consists of two group 27 twelve volt batteries so I guess I should replace them with four 6 volts?
Old 12-02-2007
Nope...A group 27 is about 100-110 amp-hours. Two would be 200-220 amp-hours. A T105 6V battery is about 225 amp-hours @ 6 VDC, so two of them are 225 amp-hours at 12 VDC, slightly more than two Group 27s.
Old 12-02-2007
Excellent! I just saved some money!
Old 12-02-2007
I only charge 5% of what you saved...
Paralleling Batteries dave.verry Gear & Maintenance 79 11-27-2006 11:19 AM
Making Amps Shack Gear & Maintenance 18 09-23-2006 09:02 AM
Golf cart batteries hathanger Gear & Maintenance 8 03-13-2005 03:23 PM
6 Volt Batteries vs 12 Volt ABullard Gear & Maintenance 10 09-06-2001 05:41 PM
