12-02-2007
seam...
Often, if you have corrosion anywhere in the line, you can detect (say) 12 V at the terminals, but the moment you try to draw a load, the corrosion chokes off the current.
Take another bulb out to the light fitting, and you will probably see that the bulb will not light either.
Sounds like corrosion... this is a classic symptom I noticed.
