scratched port lites - SailNet Community
post #1 of 16 Old 12-02-2007 Thread Starter
Good evening all.
The solid plastic (acrylic?) non-opening portlites on my cabin are 20 years old and while translucent, I certainly cant see anything through them. They seem to be fairly thick. I was told I could polish them out to get rid of the fine scratching that obscures vision. Anybody know the best procedure?
scosch is offline
post #2 of 16 Old 12-02-2007
Yes..Tommyt sent me a product called Prism Polish.
Its like ultra secret and you can only buy if you go to a special convention
See here
Giulietta is offline
post #3 of 16 Old 12-02-2007
Senior Moment
SailorMitch's Avatar
Also try Flitz Metal Polish. It does wonders on plastics as well. (But at 20 years of age they are probably shot.)
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
SailorMitch is offline
post #4 of 16 Old 12-02-2007 Thread Starter
thanks, Ill check it out. I thought Id have to go through a 600/ 1000/2000 etc sanding regime.
scosch is offline
post #5 of 16 Old 12-02-2007
MacGuire's Mirror Glaze polish and cleaner can give good results too.. but if your ports are seriously opaque you will not likely get a completely clear view without changing them.
I hear Flitz is becoming hard to find.
Faster is offline
post #6 of 16 Old 12-02-2007
scosch
Not that long ago I wrote about how successful I was using Prism Polish on my 30 plus year port lights. I was so excited and expounded on the virtues of the product to such a degree, that I was accused of being a spammer. Only the intercession of camaraderie saved me from being electronically tarred and feathered. If you search this forum you will find my thread. Just be careful how you praise the product. Some members can be very quick to heat the tar!!!
JLBJR
JLBJR is offline
post #7 of 16 Old 12-03-2007
Valiente's Avatar
I'm going to check that out. I have 1/2 inch Lexan fixed ports in my pilothouse I am loath to change due to the fact that they are well installed and to physically replace them would be expensive. But they are somewhat scratched (not badly crazed) and even eliminating half of that would be a big improvement.
Valiente is offline
post #8 of 16 Old 12-03-2007
poopdeckpappy's Avatar
I use to remove scratches from my UW housing with toothpaste
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #9 of 16 Old 12-03-2007
Seasoned Salt
Trekka's Avatar
I also recommend Flitz Metal Polish, which comes with a polishing ball for your drill. It's non toxic so no fumes or skin irritations. I encountered Flitz at a sailboat show this fall and was interested enough to come back with an old pane that was as heavily colored and scratched as the 27 yr old panes on my boat. (The PO changed this one out, but then passed away before he could do the others). It worked really well! It will not undo the internal effects of aging - none will. But it did a beautiful job of cleaning and polishing the surfaces.
Trekka is offline
post #10 of 16 Old 12-03-2007
I don't discuss my member
zz4gta's Avatar
I'll second poopdeckpappy. Tooth paste works well on minor jobs, and its cheap.
Merit 25 # 764 "Audrey"
zz4gta is offline
Documented Boat Name and Hailing port Tree Gear & Maintenance 11 06-08-2011 12:20 AM
Number of race entrants up from 2006 - Port Huron Times Herald NewsReader News Feeds 0 07-16-2007 07:15 AM
Boat Week is Port Huron's time to shine - Port Huron Times Herald NewsReader News Feeds 0 07-15-2007 07:15 AM
Race day gives fans a reason to keep coming back - Port Huron Times Herald NewsReader News Feeds 0 07-18-2006 08:15 AM
Brothers fall just short of winning race - Port Huron Times Herald NewsReader News Feeds 0 07-17-2006 09:15 AM
