11-10-2011
they came out very easily... at least the two in the main salon, no reason the others shouldn't. The old caulking is quite brittle and parts easily with gentle pushing around the frames. Four hands might be better than two but it really was not difficult. The problem was more getting them back in with the (very sticky) tape on the frame. The outer frame has about a 1/2 inch flange for sealing but the builders didn't spare much time cutting out the template hole so it took some playing around to get the outer frame back in and in a suitable place that there was enough fibreglass to mate against all 'round with the tape. I did have to grind it out a bit to make a bit more room and this was definitely a two person job. I now realize I did it a bit backwards, should have positioned the outer frame first, drawn a thin pencil line once properly situated and put the tape on the fibreglass, not the frame. Live and learn. :-|
Be careful with the Philips screws on the inside, they seem to be some weird head and some weird thread, I couldn't get a screwdriver to fit them properly and they'll be impossible to replace unless you want to get rid of them all and retap with some 'regular' machine bolts. (use fine thread)
