12-03-2007
If USCGRET is correct, then it is probably bilge water, not osmosis or a crack through the hull.
Originally Posted by USCGRET1990
Drill 1/4" holes in the area to drain it. It's not good for it to freeze inside.
If it's weeping, there's already some sort of break in the glass. Stop drilling if/when the drill bit starts to spit out lead. Creamy yellow is most likely oil emulsified in (salt)water.
