Old 12-03-2007
liquidjoel is on a distinguished road
Send a message via AIM to liquidjoel Send a message via MSN to liquidjoel Send a message via Yahoo to liquidjoel
Water Leak from Swing keel
Hello,
I have a Venture Newport / Macgregor 23. Two trips ago, the keel was dropped too fast. Now last weekend, water started leaking from what appears to be the bolt that the keel swings on. I was hoping someone could advise me on how to repair this.
I was also going to leave the boat in the water and am concerned that if I do this without the problem resolved it could fill up with water to the point that the foam flotation will be what keeps the boat from sinking. Does anyone think that this is something to worry about?
Thanks,
Joel
Old 12-03-2007
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Joel, first off, you don't have a bilge pump? If you're going to leave a boat, any boat, in the water for extended periods you'd better fit one or you neighbours will get upset having to avoid yet another sunken wreck.
To fix the pivot bolt, you'll have to take the boat out of the water, drop the keel out and fill and rebore the bolt hole before putting it all back together again.
It's not a big job, but not possible to do in the water.
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 12-03-2007
Here .. Pull this
Sailormann will become famous soon enough
You can probably seal it with something as a stopgap, but to fix it properly you are going to have to take the boat out of the water. The easiest thing to d would be to drill the hole out a little larger through everything and fit a slightly larger bolt.
Yes. Seal it or take the boat out of the water and fix it.
Old 12-03-2007
kwaltersmi's Avatar
Broad Reachin'
kwaltersmi is on a distinguished road
There's typically a rubber gasket on both sides of the keel bolt, or at least there is on my boat. You may not need to drill the hole out. Check the for gaskets and replace those if they seem rotted or ripped.
Old 12-03-2007
Joel73's Avatar
1987 Pearson 27
Joel73 has a spectacular aura about Joel73 has a spectacular aura about Joel73 has a spectacular aura about
the name thing...
Joel,
I have absolutely no idea how to fix that... but welcome to Sailnet.
-Joel
"Unthinking respect for authority is the greatest enemy of truth." - Albert Einstein
Swing Keel or Fixed Wing Keel? Catalina 22 or 25? BRCincy Boat Review and Purchase Forum 53 03-07-2012 04:13 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
The Dreaded Keel Bolt Leak Mark Matthews Gear and Maintenance Articles 0 04-07-2002 08:00 PM
Swing Keel Dilemma SailNet Gear and Maintenance Articles 0 07-12-2001 08:00 PM
