Old 12-04-2007
SVGratitude's Avatar
SVGratitude is on a distinguished road
Universal M35 Heat Exchanger Replacement
There is air leaking into the raw water side demonstrated by pressure testing the fresh water side and bubbles being formed in dish soap at the vented loop.
I assume I need to change/repair the heat exchanger on my M35B. Removing and replacing the unit seems to be pretty straightforward.....a bolt on type affair.
If anyone has replaced theirs, is there anything that has a tendency to "bite you" with this procedure?
Thanks
Mark
SV Gratitude
Catalina 36
Old 12-04-2007
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
Originally Posted by SVGratitude View Post
... I is there anything that has a tendency to "bite you" with this procedure?
The price?
Old 12-04-2007
HoffaLives's Avatar
HoffaLives is on a distinguished road
i found elbow room was an issue when i pulled mine to replace a gasket and clean it out. i bought a set of ratcheting box end wrenches and it made it easier than it would have been.
red peril
severodvinsk class russian submarine
1993
364 feet
our life afloat:
Old 12-04-2007
pegasus1457's Avatar
Arf!
pegasus1457 is on a distinguished road
Originally Posted by Idiens View Post
The price?
Why? Don't you think $488 is a bargain?
Yoicks!
Old 12-04-2007
Idiens's Avatar
Larus Marinus
Yoicks!
A bit of a nibble, I suppose, On my old Volvo it was 3500 euros. - That's more of a bite.
Heat exchanger cap partial failure Valiente Gear & Maintenance 9 06-01-2007 12:09 AM
Transmission Heat Exchanger gconley Gear & Maintenance 7 11-05-2006 09:45 PM
Heat exchanger cleanup and cleanout dargiem Gear & Maintenance 2 01-31-2003 04:52 PM
Heat Emergencies William Mahaffy Seamanship Articles 0 12-18-1998 07:00 PM
Heat Emergencies William Mahaffy Her Sailnet Articles 0 12-18-1998 07:00 PM
