My Helms 25 has closed body turn buckles and I was planning on changing them out in the near future. What are the pro & cons of closed vs. open body turn buckles? I know it’s hard to judge where the end of the threads are on my closed body turn buckles. Is one stronger than the other? I have 5/32 wire and 1/4" pins as a frame of reference.
I like the open ones as you can see how much thread is left and what condition things are in. I rarely see closed ones on boats over 20 feet. i don't think there is any appreciable difference in strength.
One of the problems with closed turnbuckles is that they rust inside and you can't see it. Even stainless oxidises. In fact it corrodes faster if its enclosed. Open turnbuckles avoid this.
__________________ !! WARNING !! The above information is to be used by intelligent people only. If you are Stupid, could be considered a moron, or otherwise. You are instructed to disregard this information and seek the help of a licensed and bonded professional.
The terminal ends on the shrouds can be secured with cotter pins, rings, wire, etc with open body turnbuckles. This prevents the turnbuckle from loosening once the shroud tensions are set. This can't be done with the closed body types.
Love many. Trust few. Always paddle your own canoe.
Open turnbuckles tend to hold less water, which reduces the likelihood of them corroding. No real reason to ever go with closed body turnbuckles IMHO. I like Silicon Bronze hardware better than the stainless...but it is harder to find.
Sailingdog Telstar 28
If you're new to the Sailnet Forums... please read this POST.
Devils advocate:
They look cool. If you are a freshwater sailor the corrosion issue isn't really problem. But, avoid lockuts at all cost. They can create huge extra stress where there shouldn't be any.
BTW, a good place to get them from is down the street from where I keep my boat... Rigging Only is a good rigging shop with excellent prices.
