12-06-2007
The trick is to use adhesive-lined heat shrink tubing... using the regular heat shrink tubing is worthless...it'll just trap water in the join. BTW, you shouldn't have to tin and solder a properly crimped butt connection.
waterproof crimp connectors are adhesive-lined, though you're correct that simply using heat shrink tubing over a standard connector achieves little.
but using proper tinned marine wire is also important. they only used cheap copper wire, (lamp cord?) and even after cutting it back a foot from the old end, it was still heavily oxidized. i'm going to have to replace that wire or else it will fail at some point.
it is surprising how some folks think wiring crucial components like this is the same as wiring a car stereo. I suspect it might have something to do with the do it yourself emphasis on boat ownership, when not everyone has the skills, or worse, has just enough.
the water coming in is rain water. from the anchor locker. the hatch has an opening to allow the chain through, and it funnels a lot of water down into the bilges, especially when we get the torrents like we've had recently. i think i want to find a way of blocking that up.
red peril
severodvinsk class russian submarine
1993
364 feet
our life afloat: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
