Blogs
User Name
Old 12-06-2007
marcusn marcusn is offline
marcusn is on a distinguished road
comanionway hatch- temp. replacement?
I need to remove my sliding hatch to do some repair work. Might take a week or so. Any suggestions on how I could fairly easily keep the cabin protected from weather and people?
Thanks
Old 12-06-2007
timebandit timebandit is offline
timebandit is on a distinguished road
How about a piece of 1/4 inch plywood for a top and two 2x2 across under the hatch . 2x2's attached with bumper bolts with just enuff play to slide just enuff to remove the boards and use the present lock attached to the new lid.
Old 12-07-2007
kwaltersmi's Avatar
kwaltersmi kwaltersmi is offline
Broad Reachin'
kwaltersmi is on a distinguished road
Saran Wrap and a pitbull. Or you could use timebandit's idea. Your choice. :0
S/V Hannabel - Helms 25, Hull #44
Home Port: Grand Haven, Michigan
Sailing Blog: http://www.sailblogs.com/member/dreambegins/
Old 12-07-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Depending on how long the sliding hatch is going to be off the boat, it might be wiser to go with something a bit heavier than 1/4" plywood. It would be pretty simple for someone to break through 1/4" plywood. 3/8" or 1/2" would be far more secure IMHO, for not a considerable increase in costs.
If you're new to the Sailnet Forums... please read this POST.
Display Modes
vB code is On
Engine Access Hatch, Fuel Pump Replacement Advice ahalfon Gear & Maintenance 2 07-08-2007 03:25 PM
Lexan Replacement Hatch for C30 latitude9.5 Gear & Maintenance 1 07-04-2006 12:14 PM
Resolving Hatch and Portlight Problems Tom Wood Gear and Maintenance Articles 0 03-17-2003 07:00 PM
Hatch Glass Replacement hamiam Gear & Maintenance 4 05-21-2001 06:43 AM
Companionway Hatch Replacement danohayes Gear & Maintenance 1 03-09-2001 09:56 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
