12-10-2007
Courtney the Dancer
We just prepared our boat for shipment (Honolulu- Seattle). I agree with the advice above to leave halyards in place. Get some of that clear wrapping plastic on a wide roll and some packing tape. Tie the halyards to the mast and then go around them with the plastic and then tape it. We bubble wrapped the entire mast and then used the plastic so the mast was completely covered, but you may not need this depending on how far the boat is going. We also took all of our standing rigging off so that no wire would chafe on the mast while pounding down the freeway, the company told us some masts have been completely ruined by this (ours is being trucked from San Diego to Seattle). Also, make sure they use carpet pads under the mast where it will be in the cradles and where any straps contact the boat. One other detail, wrap the top and bottom of the mast so you don't get road grit all through the sheaves and inside the mast. Good luck, our boat arrives this Friday or Monday. I'm a bit worried that I didn't get everything winterized in Honolulu, kind of hard to find RV antifreeze over there! Best of luck, John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
