12-13-2007
The ATN TopClimber will allow you to go up the mast without needing a second person below to winch you up.
If you go up on a bosun's chair, I would recommend you use an line ascender on a second line as a safety measure.
LED masthead lights rock... I have an OGM Tri-anchor light on my boat.
I don't think you need to pull the mast for installing the LED masthead light or retrieving the halyard. As SailorTJK1 suggests, you should get used to going up the mast... as it is a normal part of maintenance and such on a sailboat.
