Old 12-13-2007
thesnort's Avatar
thesnort is on a distinguished road
Inspection of a Hypalon Sailing Dinghy
Howdy,
What clues should I be looking for in a 10-year old inflatable? Would a slow leak put you off from buying, or is Hypalon easily repaired? If I don't bring it in for repair, I thought Eternabond tape might do the job. (Any ideas on the cost of repair if done by a "professional"?). Any thoughts on what would work best with hypalon? Thanks in advance.
Old 12-13-2007
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
Odd! I have a ten year old Hyperlon inflatable - with a slow leak.
Slow enough to make it difficult to find the leak and fast enough to be a nuisance.
I regard the dingy as shot. But if anyone would care to buy.... ???
Old 12-13-2007
A slow leak in a ten-year old inflatable is probably a sign that it will be sprouting more leaks shortly. I would avoid buying one with a leak, especially since some leaks aren't readily repairable, like where the tubes are joined...
Old 12-13-2007
Lion35 is on a distinguished road
If you have a puncture or tear in Hypalon, not a slow leak, I recommend patching from the inside and outside with Hypalon patches with 3m 5200.
My Avon got slashed years ago and I unsuccessfully tried patching it with the Avon repair kit multiple times until a cruising friend recommend using 5200. The 5200 repair isn't as pretty but has held up for about 5 years now and is still going strong.
Old 12-13-2007
thesnort's Avatar
Thanks so much for your quick replies. The owner states that it is a slow leak near a valve on an outer tube of a Tinker. I reaallly like these sailing dinghies and was hoping to pick it up over the weekend. The price seemed right at $1,500, but I don't know what to think about the slow leak. I know there's hypalon paint that flexes with the boat. I thought that might do the trick too.
Old 12-13-2007
Valiente's Avatar
Have you had demonstrated to your satisfaction that it is the tube and not the valve? On my Zodiac I had a crappy valve (they screw in separately and have a plunger type spring device with a "leather") and when I replaced that, I got hard and stayed hard.
So to speak.
Old 12-13-2007
FortAwesomeIII's Avatar
FortAwesomeIII is on a distinguished road
My Mercury Hypalon inflatable began to sprout leaks all over(very small ones) after only about 3 years. I would make a warranty issue about it, but since the transom joint is coming loose(covered only on a 1 yr warranty), it's useless. Looks like I need to get a better quality tender1
John Pate
Highport Marina ZD27
aboard S/V Fort Awesome III
"I couldn't do the things the way those people do.
I couldn't live there if you paid me to. "
The Talking Heads
Old 12-13-2007
SVDistantStar's Avatar
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
My 20 year old Avon is still going great. I patched a small cut useing a tire patch and its holding fine. I do have a valve that has a slow leak, but i dont mind topping it off everyday. Its a hardbottom boat, so i can afford to buy a replacement for it right now.
Old 12-13-2007
Cruisingdad's Avatar
Best Looking Moderator
I think ALL inflateables leak... somewhat. But 1500 seems high to me??? But I have not really researched the cost of used, er, hmm, I mean Experienced tenders!
HAHA!
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 12-13-2007
Idiens's Avatar
Larus Marinus
Although the Tinker has a good name and is expensive by inflatable standards, at 10 years old, it sounds expensive to me.
Sailing Lesson ASA vs. Localing Sailing Center Stryker72 Learning to Sail 14 12-23-2008 12:49 PM
Cruising Multihull Sail Trim Kevin Jeffrey Buying a Boat Articles 0 10-05-2004 08:00 PM
Optimist Sailing—A Growing Concern Carol Bareuther Racing Articles 0 07-15-2002 08:00 PM
Nelson Sailing Dinghy sailboatshark General Discussion (sailing related) 0 12-08-2000 02:03 PM
