Swage vs mechanical fittings - Page 2 - SailNet Community
View Poll Results: Swage or Mechanical?
Swage 1 6.67%
Mechanical 14 93.33%
Voters: 15. You may not vote on this poll
post #11 of 13 Old 12-16-2007
IslandRaider's Avatar
I to am planning to re-rig this coming spring as the current rig is 18+ years, I currently have wire every where except the aft stay which is rod, the plan is to use mechanical at least on the bottom, an i am going to maintain a rod aft stay, as i will be doing some recreational racing. was not familiar with the hi mod fittings but sound like they bear some investagating. thanks to all for the input
S/V Privateer
42' Morgan Custom
IslandRaider is offline
post #12 of 13 Old 12-17-2007
Swagged and Mechanical fittings
I replaced my shrouds and stays as you intend with swagged on top and mechanical on bottom. Chose that route initially to avoid corrosion in lower fittings, but appreciated the cost savings by reducing the number of mechanical fittings. I used sta-lok, but am disappointed with surface corrosion after just a few months. They are very simple to assemble but a bear to take apart, probably not possible in an emergency situation. If I were going cruising I would carry a couple of fittings for each size wire on the boat (three in my case). that is expensive but I wouldn't count on being able to take one apart quickly.
John
ccriders is offline
post #13 of 13 Old 12-17-2007
sailboy21's Avatar
For emergency repair, don't forget several of the mentioned companies offer extended studs, or even splice connections. ccriders, same impression about stalock. The way the fitting ends up crushing the wire around the cone, could be very hard to get apart. Also, when gooped up with sealant as recommended, they do seem to hold water resulting in corrosion. All the dockside experts condemned my rig since I did not use any sealant. Being a little concerned, I called up Hayn tech support. I highly recommend doing this, those guys know what they are talking about, and are very happy to answer your questions.
sailboy21 is offline
Broken forestay brak Gear & Maintenance 31 09-24-2010 12:34 PM
Standing Rigging Basics Mark Matthews Racing Articles 0 08-29-2004 08:00 PM
Swaging Fittings Tom Wood Gear and Maintenance Articles 0 04-24-2002 08:00 PM
