Blogs
User Name
  #11 (permalink)
Old 12-17-2007
soulesailor's Avatar
soulesailor soulesailor is offline
blue collar cruiser
soulesailor is on a distinguished road
I hope this isn't a hijack~ but I'm in this situation, too.
Sailingdog, could you continue your method's explanation for me? I'm with you up to the point where the mast is raised vertically and free, but then what? Getting that unwieldy beast from vertical to horizontal seems like a TIMBER! type situation.
Voice or no voice, the people can always be brought to the bidding of the leaders. This is easy. All you have to do is tell them they are being attacked, and denounce the pacifists for lack of patriotism and exposing the country to danger. It works the same in every country.
-Hermann Goering, Hitler's Reich-Marshall
Nuremburg trials
  #12 (permalink)
Old 12-17-2007
blue collar cruiser
Sorry, I meant Gramp34, not sailingdog
Nuremburg trials
  #13 (permalink)
Old 12-17-2007
TIKI TIME's Avatar
TIKI TIME TIKI TIME is offline
TIKI TIME is on a distinguished road
If you have a couple of friends with like size or larger sail boats, you can dock your boat in between the two boats and use the other boats main halyards to lift your mast.
One man on each halyard winch cranking in unison can make this task a piece of cake.
The boats were docked in slips and tied up which I feel is necessary, as the two outer boats did try to heal over till the dock lines became tight.
Good luck.
  #14 (permalink)
Old 12-17-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Assuming you're lifting the mast somewhere close to and slightly above the mast's center of gravity, the easiest way to tilt the mast to the horizontal position is to take a line around the base of the mast and haul in on it—towards the crane or whatever is holding the mast up, and lower on the line that is holding the mast up. This will cause the mast to tilt back as you pull in on the mast foot and lower the mast.
I posted this earlier...but it disappeared, and I'm posting it again in case it'll help anyone else...
If you're new to the Sailnet Forums... please read this POST.
  #15 (permalink)
Old 12-18-2007
sailboy21's Avatar
sailboy21 sailboy21 is online now
sailboy21 is on a distinguished road
I used 3 people for my mast:
One to operate the "crane"
One person removes and secures the standing rigging.
Another holds the base of the mast, and guides it off the step.
The rigging guy then comes to the mast and helps walk the bottom end forward while the crane guy lowers it.
We used a 2:1 purchase and wrapped the lifting line around a winch. If you have halyard winches (weight) on the mast you can lift it from the middle, otherwise as mentioned a little above the CG.
  #16 (permalink)
Old 12-18-2007
Sasha_V's Avatar
Sasha_V Sasha_V is offline
Sasha_V will become famous soon enough
We med moored in a canal running through a park and used a big tree. Just climb up the tree to the right hieght and tie on a loop of rope with a block. Thread rope through block and you are in business.
I would not bother with all the talk of block and tackles. A) you can work that weight with one man just on a turning block and B) you can always run the rope back to an onboard winch and crank away.
Sasha
  #17 (permalink)
Old 12-18-2007
sandsailor's Avatar
sandsailor sandsailor is offline
capt'n
sandsailor is on a distinguished road
fortunetly for you i had this problem once
so i now make such a problem solver among other items not available else where to my knowledge
the first one is the solution to the second one being the problem
with this i can step the mast my self with the help of the mainsheet tackle and a winch from the cocpit
Sand Sailor
  #18 (permalink)
Old 12-18-2007
TejasSailer TejasSailer is offline
TejasSailer is on a distinguished road
The method suggested by TiKi Time has been used for boats up to 37' where I am located.
  #19 (permalink)
Old 12-18-2007
chucklesR's Avatar
chucklesR chucklesR is offline
Gemini 105Mc Hull 987
chucklesR is a jewel in the roughchucklesR is a jewel in the roughchucklesR is a jewel in the rough
We used to drop 36 ft whip antenna's (about 200 pounds) without cranes when I was in the Navy. It didn't pass the safety officers most cursory glance, but it got the job done and liberty commenced on time.
Disconnect the shrouds and have one guy on each side hold them - they are guides. Have one BIG guy sit and hold the base. Have two guys lift the mast up, with the mast off the deck sitting on the big guys lap the two guys that are lifting it can start to rotate the top down by walking it backwards. At some point the big guy passes the base off to the shroud guys who lift it and walk it backwards.
It works, but if the base gets away it's all over for the big guy. Whip antennas don't have shrouds, we just manhandled it up and down Iwo Jima flag raising style. Lost one big guy's sack (clean slice, partial twig, both berries) when the mast pounded home so from then on we got a crane
  #20 (permalink)
Old 12-18-2007
chucklesR's Avatar
True story BTW, in 1983 onboard USS Ponce, LPD 15, inport Norfolk Va; RM3 James Baker lost most everything, RM1 lost 2 stripes 2/3 pay for 2 months and no body got liberty that night
Display Modes
vB code is On
Deck stepped Mast-Always Bad ? Mrs Mutiny Buying a Boat 23 02-01-2008 10:05 AM
Southern Cross 31? db27513 Buying a Boat 35 09-24-2007 10:58 PM
30ft Catalina BigRuss Buying a Boat 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
Small Boat Mast Stepping SailNet Gear and Maintenance Articles 0 06-12-2002 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
