12-18-2007
Generally, sailboats shouldn't depend on their auxiliary engines in an emergency... the engines are far more likely to fail than a properly used rig is...
Hull speed on a 21' sailboat is about 6 knots, probably a bit less since the waterline is shorter than 21'. A 10 HP engine, properly propped, would get you close to hull speed, if not up to hull speed... so if the tidal currents are 7 knots... you'll be wanting to plan your trips accordingly.
