12-21-2007
Oil Pressure Mystery Solved
The oil pressure on my Perkins 108 has read 80psi since the day I bought the boat, a Challenger 32, I figured a constricted oil way so have changed the oil about 5 times and used a sludge remover each time. I had recently made a new instrument panel and installed all new gauges, senders and wiring. Everything was fine except for the oil pressure being so high, then I had a problem with the temperature needle not moving from 180. All the instruments were Teleflex, bought from Defender, so I emailed Teleflex tech support and started a dialogue with Joe. He was very helpful and told me how to test the gauge, which I did, but in the process I noticed the oil pressure gauge read 40psi without the engine running (I don't use a key switch, an oil pressure switch turns on the juice to the instruments). I mentioned this to Joe and he had me check the oil sender ohms, turns out I'd mistakenly ordered a two station sender instead of a single. The strange thing is that the PO (a group of 3-4 people co-owned the boat for a few years) must have made the same mistake, I have the original log book and read an entry that noted high oil pressure, but no mention of changing the sender. Anyway, I posted this, for what it's worth, as an experience that may save someone else a fair bit of frustration. Incidently, remove the signal wire before you test the ohms of a sender.
All the best
Ignorance will let you die in innocence, but awareness will at least let you know what the mistake was.
