12-25-2007
If you have the ST60 Tri-data, then you'll get true wind angles, based on the knotmeter readings... of course, if there's a strong current, it won't be 100% accurate...but close enough for most people.
Originally Posted by fireman181
I thought connecting the two would give True wind direction while under way, and also tacking angles, useful while racing,...........but not worth $100 ...........Thanks
