-   -   What is this black stuff? (http://www.sailnet.com/forums/gear-maintenance/39449-what-black-stuff.html)
davidpm 12-25-2007 03:21 PM
1 Attachment(s)
We have a leek in a 1987 Catalina 27'. We started grinding and this picture shows an area at the very top of the keel on the starboard side about in the middle of the boat. This boat has a glass skeg keel of about 12” with the lead keel affixed to the bottom of that. The lead glass joint looks good. This picture is taken from the center of the glass skeg on the starboard side about in the middle. From the bottom looking up the picture clearly shows:
1. Red bottom paint
2. Gel coat,
3. Large Dark green band (very hard)
4. Small White band (Caulk like but rather soft)
5. Large Black band (Like putty very, very soft)
6. Tan, Pink (Very Hard)
It looks to me like #6 is good glass.
What is #5 it is worthless?
What is #4 it is not much better?
What is the #3 layer
The two layers of softer material white and black (about 1/8”) is between the solid dark green layer and the tan pink layer #6 from the shaft log to as far as we have ground, which is now mid keel.
Also about half of the #6 layer is spider cracked and crumbling and we ground through the hull.
This boat was grounded before by the previous owner and repaired by the yard in an area of about 6” by 24” primarily with bondo directly behind the keel.
sailboy21 12-25-2007 03:56 PM
That is the stuff that chemically holds the resin together.. styrene I think. The result of osmosis my friend.
SEMIJim 12-25-2007 04:14 PM
Well... Were it not for the colours being all wrong, except for the black, I'd say it's the result of a busted-up ship off a coast line--perhaps in a shallow bay.
Jim
sailingdog 12-25-2007 04:31 PM
Originally Posted by davidpm (Post 241687)
1. Red bottom paint
2. Gel coat,
The green looks like fiberglass. Fiberglass is often greenish or pinkish.
No idea what this stuff could be... best guess is that it is sealant of some sort.
This sounds like it was wood or some other organic material that just rotted.
Also, looks like fiberglass. As I said above... Fiberglass is often greenish or pinkish.
The two layers of softer material white and black (about 1/8) is between the solid dark green layer and the tan pink layer #6 from the shaft log to as far as we have ground, which is now mid keel.
This boat was grounded before by the previous owner and repaired by the yard in an area of about 6 by 24 primarily with bondo directly behind the keel.
Freesail99 12-25-2007 05:10 PM
The soft caulk like stuff, maybe boatlife. I had it on my boat around the cutlass bearing tube.
rhaley 12-25-2007 06:51 PM
Have you got another pic from further away that puts the position of the ground out spot in perspective? Catalina used plywood in the bottom of the bilge sump in this era C27, but it is hard to tell exactly where the black band is on the keel.
Ryan
82 C27
sailingdog 12-25-2007 09:19 PM
Hmm... the plywood would be a good candidate for the black stuff...especially if it was rotten. :)
davidpm 12-25-2007 09:20 PM
1 Attachment(s)
This shot is from the starboard stern side. A couple of inches out of frame to the left is the engine saltwater intake. The first shot it at the same elevation (just at the point where the bilge of the boat curves down to the skeg) about 6" to 12" to the right.
I just never expected so many colors and donn't know what they mean. The black spots under the hole are solid so the blackness itself may not be evidence of rot.
rhaley 12-26-2007 08:51 AM
David
Does that hole in the second pic open into the bilge?
Ryan
davidpm 12-26-2007 09:38 AM
Yes. This location is a few inches forward of the engine water intake. It was covered with the soft black layer and had soft glass underneath so it had to be ground out.
Some of the black layer is hard Some is hard and over solid glass, some is soft over solid glass and some is soft over delaminated glass.
I'm leaning towards the theory that it was repaired more than once. That would explain the normal glass at the deepest layer and the blue glass near the surface. Still donn't know what the black layer is.
Plywood sounds unlikely but maybe if they used a plywood form to cover with glass.
