12-27-2007
Jon—
Those little studs should ideally be screwed into thickened epoxy, or through bolted. If they're just screwed into caulk in the deck and the deck is cored, you're in for a rude awakening when they leak and cause the core to delaminate.
As for the hack job on your hatch... you need to remove the lexan and clean off all that silicone... and then rebed the lexan properly. There are some commercial cleaners designed to get rid of silicone sealant...but getting the bulk of it off with a razor blade would be a good idea. If you use a razor blade... use some fine sand paper and round the corners of the blade, so that they don't dig in and scratch the hell out of the aluminum or lexan.
