Old 04-28-2002
docsabre is on a distinguished road
Paint OFF Hull
Was able to get the old name off with Fibergalss safe stripper. I am now left with a light colored outline that seems to be in the glass. How can I get it out? Do you think buffing with compound would work. Sanding with 600 grit did not do it.
Thanks
  #2
Old 04-28-2002
RichH's Avatar
RichH will become famous soon enough
Paint OFF Hull
The outline will fade in time, just be patient.
Sand with 600, then, 1000, then buff with 1300grit compound, then 2000 grit compound, seal with water and wax, then buff ..... for perfect restoration
You may post attachments
You may edit your posts
Glassing hull GreenEarth General Discussion (sailing related) 18 06-19-2009 11:52 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Hull speed and wide sterns Jeff_H Boat Review and Purchase Forum 24 11-21-2006 11:58 PM
hull construction cgha33 Boat Review and Purchase Forum 4 05-23-2003 07:11 PM
Bottom Job question(s) rookie00 Gear & Maintenance 19 03-19-2003 03:01 AM
SEO by vBSEO 3.6.1
