Old 12-30-2007
HoffaLives's Avatar
HoffaLives is on a distinguished road
new kind of wind power?
this looks deceptively simple. i wonder if they have larger versions?
http://www.thethinkingblog.com/2007/...per-cheap.html
red peril
severodvinsk class russian submarine
1993
364 feet
our life afloat:
Old 12-30-2007
Sasha_V's Avatar
Sasha_V will become famous soon enough
Nice prototype...It would get a lot more complex in order to be of practical use. Firstly there would need to be a system that controlled tension so that it could vibrate at an efficient frequency in relation to wind-speed.
you still need at least one bearing to allow the thing to pivot so as to present its flat face to the wind (which means adding a tail-plane)...On the bright side, you would not have just one belt vibrating per unit...think in terms of six or ten or an entire venetian blind type effect...
Downside....Has the potential for major noise as a byproduct.
Sasha
Old 12-30-2007
Valiente's Avatar
Interesting. The thread comments seem moronic, though.
I wonder what the output curve is like? You could mount big ones on a pole, and have them weathercock into the wind. The main problem I see is that they would quickly corrode in sea air...I don't know how you could keep the vibrating membrane (does it induce electricity in coils? It's unclear how mylar is part of this to me) moving freely and yet keep the coils and the conductive bits dry.
Old 12-30-2007
nsheehan615 is on a distinguished road
the mylar is used to move the button magnet (just like in those cool LED flashlights that you shake back in forth) Mylar is great in a sea environment, the problem would be UV. As for as the coils dry, I don't know??
Old 12-30-2007
Valiente's Avatar
Oh, I see...the magnet is glued to the trembling mylar, and the magnet movements induce current in the coil.
Why not make a thicker form of magnetic tape (coated with ferrous oxide, just like audio tape) and coat it against the elements?
Damn, I barely grasp the technology and I'm trying to improve it...typical boater.
Old 12-30-2007
AmicaJim is on a distinguished road
Very interesting! It could even be delivered as a kit for survival use to power a small transmitter. Like Sasha, when I watched the demo, the first thing that I thought of was noise, much like a humming backstay, but worse.
Old 12-30-2007
stuck 'behind bars'
Robby Barlow is on a distinguished road
Send a message via MSN to Robby Barlow Send a message via Skype™ to Robby Barlow
Just wondering what speed the fan was running at to produce electricity from that reduced scale model and what type of hurricane you would need to run the full size version.
If you want to keep your shadow behind - walk facing the sun !
________________________
www.starykon.blogspot.com
UK & Netherlands. Tacktick to exhibit new Micronet Power Boat Wind ... - BYM News (press release) NewsReader News Feeds 0 11-02-2006 03:15 AM
Electrical Power on Board Kevin Jeffrey Gear and Maintenance Articles 0 02-11-2003 07:00 PM
Electrical Power on Board Kevin Jeffrey Her Sailnet Articles 0 02-11-2003 07:00 PM
Understanding Apparent Wind Steve Colgate Seamanship Articles 0 11-10-2002 07:00 PM
Reading the Shape of the Wind Carol Cronin Racing Articles 0 07-18-2002 08:00 PM
