Old 01-01-2008
Perithead's Avatar
Montgomery 17
Perithead is on a distinguished road
Securing wiring throughout a fiberglass innerhull?
I have an '83 Mac 25 and I am getting it ready for some more serious and longer trips. One of the things I am doing is securing the wires that run thoughout the boat ever 12" or 17".
I have some small plastic piece that have a ring where you can put wire though it and it has a small flat surface with some doublesided sticky foam so you can "stick" them through out your boat wherever you need them. I dont think I want to trust these to hold up all my wires. Is there any other way I could attach them?
All the "wire secure'ers" will be attached to the inner hull shell so I could put small through fittings to hold them in place (the only backdraw I see is that when inside of the cabin you will notice various screw heads thoughout. Is this my only other option? Is putting small holes in my cabin floors, bullkheads, and such really a good idea?
I am looking for the simplest way out there and any opinions would be appreciated.
OR are the sticky things my best bet?
BUT can I trust them?
Old 01-01-2008
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
I use the sticky pad approach, but the surface does need to be very flat and clean.
Jonathan-Livingston
Old 01-01-2008
HoffaLives's Avatar
HoffaLives is on a distinguished road
i wouldn't use sticky pads; they aren't really a permanent approach. you need to find a way to permanently attach the wire straps. one way would be to epoxy a length of wood along the liner and attach to that.
red peril
severodvinsk class russian submarine
1993
364 feet
our life afloat:
Old 01-01-2008
Perithead's Avatar
Montgomery 17
Hoffa, yes, that would probably be the best way to do it, but it would take ages it seems like. Just think, everywhere that you have wire ran you must epoxy a piece of wood that was thick enough to screw something too?
If I have a much larger boat then I would do that, maybe. I am the type of person who looks for an easier way than that.
But in an offshore voyage, I would rather be on your boat than mine!
Thanks for that reply.
Idiens, Do your sticky pads ever come off? Or are they rather secure?
I like that idea the best but I dont know how much I can trust it.
Old 01-01-2008
Idiens's Avatar
Larus Marinus
Yes, some do occasionally come off. Usually where I didn't take enough trouble preparing the surface. Others really stick remarkably well, but of course, Hoffa's epoxy strip is best, but that needs good surface preparation too.
Jonathan-Livingston
Old 01-01-2008
Perithead's Avatar
Montgomery 17
Hoffa, if I were to epoxy something to the inner hull do you mean just put some epoxy on a block and then clean the fiberglass surface and put some epoxy on that then stick them together?
Or is it more complex than that?
Old 01-01-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
Epoxy on the block of wood alone would work. It also be better if you were to thicken the epoxy, so it doesn't drip as easy.
S/V Scheherazade
Old 01-01-2008
retclt's Avatar
Roadkillibus Texanis
retclt will become famous soon enough retclt will become famous soon enough
Small sections of tubing epoxied to the hull would work. You could change and re-route wiring easily at any time.
Bob T
"I cannot not sail" - E. B. White
Old 01-01-2008
deerenick is on a distinguished road
deerebill
If I were to fix my wiring,I would get the flat plastic squares with the small slot on top that would accept a plastic tie wrap or tie.You can get them by the bag at the hardware,they also have the peal and stick on the back that I would not trust.Instead I would put a drop of gorilla glue on each pad then tape to the bulkhead until dry.Good luck.
Bill NC
Old 01-01-2008
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
I had an '69 Islander 26 excaliber, one of the first things I did was strip all the wiring and redid it. Not having any subframing as I do now, I epoxied 3/4" x 1" PVC tubing every 16" and fed all the wires thought that, then I wrapped all the wires in some 1/2" black plastic flex jacket stuff I found at WM, the 1/2" flex stuff fit though the 3/4" PVC tubing, so when it was all done it was pretty clean.
The other thing I did was to flag each run with different colored tape every few feet so if I had to trace wire in the future it would be easier
That might have been over kill, but what the heck
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
The legacy of Philip Rhodes GoodOldBoat Buying a Boat Articles 24 03-09-2012 04:06 PM
Older Boats-How Long will they Last? JustMeUC Boat Review and Purchase Forum 78 12-18-2010 02:31 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
First Fiberglass Repair SailNet Gear and Maintenance Articles 0 09-01-2001 08:00 PM
