Old 01-01-2008
Perithead's Avatar
Montgomery 17
Perithead is on a distinguished road
Wire size between Battery and System?
I am replacing the wiring that runs from my battery to my fuse panel and I am not sure what size I should use?
I think I am supposed figure up how many volts/amps are needed to run whatever is connected to the system. I am not sure what to do when I have that number or really how to get the number. The things I am running are very basic and would not all be running at the same time.
They are as follows:
VHF
FM/AM/cd Player
Depth Sounder
1 LED 7" dome light and 2 4" LED dome lights
All running lights and anchor lights (not LED)
1 Bilge pump
I am not sure what gauge I should run. I was thinking 10 should do. Can anyone give a suppestion of what gauge I should use, or how to figure it out?
Thanks Everyone!
Old 01-01-2008
Perithead's Avatar
Montgomery 17
The distance is approx. 3'.
There isnt a main panel fuse. But there are fuses for each switch and they have 2 numbers on the fuses. 32 and 20 but I am not exaclty sure which is which at the moment.
Does that help rick?
Old 01-01-2008
thekeip is on a distinguished road
A AWG 10 is good for your purpose, 8 is better, the error is in your favor. Check on those breaker values, though
Howard Keiper
Old 01-01-2008
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Should he also have a breaker between the batt bank and Dist. Pnl ???
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 01-01-2008
bwindrope's Avatar
Break, curse, fix, repeat
bwindrope is on a distinguished road
According to Casey and Calder and perhaps ABYC, all batteries should be fused at the battery. Within inches really. I've retrofitted my electrical system with these fuses and feel very good about there being no opportunity for a short to melt my wires.
Aeolus
Gulf 32
Bainbridge Island, WA
Old 01-02-2008
camaraderie's Avatar
moderate?
Wire Size Calculator:
http://beta.circuitwizard.bluesea.com/
Battery Bank Design Kevin Jeffrey Gear and Maintenance Articles 0 05-12-2003 08:00 PM
Battery Bank Design Kevin Jeffrey Cruising Articles 0 05-12-2003 08:00 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 08:00 PM
Electrical Work Rules Don Casey Gear and Maintenance Articles 0 07-16-2000 08:00 PM
