01-04-2008
You're probably better off using epoxy resin, since it will yield a stronger bond in most cases. When thickening the epoxy to fair the exterior, use chopped fiberglass rather than microballons or cabosil (colloidial silica), since the first absorbs water and the second is a bitch to sand.
