Old 01-03-2008
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Mast Boot ( Wooden spar )
My mast is 7x9" and I looking for something better than what I'm using ( Holt mast Tape ), Spartite nor SSI can help me.
Any Clues ??? or is tape as good as I'll get
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 01-03-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
I have used in the past, water & ice shield that is used on roofs. It has a sticky side and if punctured, it seals it's self. Very easy to apply.
S/V Scheherazade
Old 01-04-2008
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
I don't know what's on mine but I love it. Not a drop of water gets by.
Old 01-04-2008
Freesail99's Avatar
The water and ice shield can be purchased at any home center.
S/V Scheherazade
Old 01-04-2008
My problem is a couple things, 1) My mast ( 7x9 ) sits in a 10x13" (OD) deck step, so the transition between the two is a booger, 2) The mast is not flat from corner to corner, so theirs a small bird mouth on each side 3) this self bonding tape doesn't seem to want to self bond very well due to the above mentioned issues
The previous owner had used duct tape, which is deteriorating and I really hate the thought of doing it the same way
I'm going over to the HDWR store and check out that roof tape that Freesail mentioned
1978 Tayana 37
Old 01-04-2008
Well, I didn't find Water & Ice shield, but I did find a butyl rubber elastic flashing tape, has a UV lifespan of 12 months, but I'm thinking I'll have the canvas guy make up a nice sunbrella boot cover and maybe extend that a bit
Anywho, thanks for the lead Freesail, I think this will work and it beats the crap out of duct tape
1978 Tayana 37
Old 01-04-2008
Freesail99's Avatar
I know you can get it 24 inches wide, if that helps, and your very welcome.
S/V Scheherazade
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
Southern Cross 31? db27513 Boat Review and Purchase Forum 35 09-24-2007 10:58 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
