01-04-2008
Thanks all for the help - bestboatawire.com looks to be the place.
Rick - I like how you did things. If I did things with seperate connectors for each use, I would have five! We have two now, with the deck light and VHR. I am adding Radar, masthead tricolor, and wind transducer. So lots more wires.
Jubilee's mast has sheaves at the bottom, so I am not sure if everything will fit. There are two channels at the front of the mast for wires. If I did it this way, I would have to remove the bottom of the mast which is pop riveted on, to gain access and make it all work. I imagine that I would have to have the exit at the front of the mast.I will consider this option when I look at the boat next!
Chris
Originally Posted by rhaley
I also use bestboatwire.com and I have had nothing but great service from them over the last few years.
As far as through deck connections, this thread shows the method that I use.
Through Deck Electrical
Jubilee
1985 Wauquiez Pretorien
