01-04-2008
AFAIK real gasoline tanks always have a vent, but that vent is supposed to be opened DURING use and SECURED when not in use. If you do not secure the vent, you will have a gasoline odor and the chance of a spill. Leaving some air space in the tank, to allow for expansion, is a good idea since otherwise the full tank could push at its seams and potentially rupture.
But when a tank is not in use? No way I'd leave the vents unsecured!
If there is a problem with the tank forcing pressure up the fuel line, that's pretty easy too. Disconnect the fuel line, that fitting should also self-seal or have a shut-off valve to use when there's no fuel line connected to it. If it doesn't find a way to cap it off, because leaving fuel in the carb will cause gum to form in the carb. With a gasoline engine that "sits" for long periods without use, you are always better off shutting off the fuel supply and allowing the engine to run itself dry--preventing the fuel in it from gumming it.
