-   -   Diesel tank access port question (http://www.sailnet.com/forums/gear-maintenance/39708-diesel-tank-access-port-question.html)
Pub911 01-07-2008 03:38 PM
Any suggestions on the most idiot(me)-proof way to cut an 8" diameter round hole in my aluminium diesel tank?
Any one ever hear of or use these guys?
http://www.seabuilt.com/index.php
or have a cheaper or better alternative?
Thanks!
camaraderie 01-07-2008 04:19 PM
The instructions for drilling the holes are here:
http://www.seabuilt.com/_pdfs/Instructions.pdf
Looks like a good product. Make sure there are no baffles internal below the cutout!!
Google hole saws for lots of options:
http://www.goodmart.com/images/prodi...Cluster_fs.gif
Pub911 01-07-2008 05:03 PM
Great! Thanks. Nice reference manterials. Do you know if they make an 8" diameter hole-saw?....or is that a jig-saw operation only?
artbyjody 01-07-2008 05:22 PM
If your tank has a internal fuel gauge / sending unit - you should be able to remove it - and use one of those telescoping mirrors to look into the tank. One thing to note that, cutting out an inspection hole - you want to make sure the tank is bone dry and allowed to air out (ie- by removing the fuel gauge / sending unit.) so that all the vapors escape.
Also, be wary of what this does for Survey purposes - tanks are tested to meet certain pressure requirements and depending - a surveyor could flag the new addition as not into specs for the particular tank (hardly unlikely but it is possible especially if it is apparent it is a DIY jobby).
camaraderie 01-07-2008 05:33 PM
