Soft shackles a good idea? - Page 3 - SailNet Community
 1Likes
post #21 of 61 Old 01-28-2011
I don't discuss my member
zz4gta's Avatar
Adam, I've used these for light air spin shackles and they work well. I flogged the sail on purpose for a while just to see if they'll hold. They did. I think if they're made correctly, they'll hold very well. I have had old snap shackles let go, interestingly enough.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #22 of 61 Old 01-28-2011
AdamLein's Avatar
Good to hear. I am thinking of picking up a few feet of dyneema today and putting one or two together over the weekend. Will be a fun project either way!
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #23 of 61 Old 01-29-2011
AdamLein's Avatar
I made two soft shackles last night! I followed the Colligo Marine video. With the first one, the center section was too short, so you couldn't make the loop big enough to go over the knot. Also it took forever to do.
Second one was measured out much better. I left the tails on so I could work the knot a little tighter by hand before trying it out... someplace. It took less than 30 minutes, mostly because I got caught up passing the end through (fids are on the boat) and had to start over.
It's 3/16-in single braid dyneema. This is from a 36-in piece. Cost $2.97 at WM. The dye seems to come out really easily.
AdamLein is offline
post #24 of 61 Old 01-31-2011
zz4gta's Avatar
Yeah, the gray/silver seems to be the natural color.
zz4gta is offline
post #25 of 61 Old 01-31-2011
tdw
Super Fuzzy Moderator
tdw's Avatar
I've been using the plain silver colour with no problems.
AdamLein, it seems to me that making them too short is a common enough problem. Even my later attempts are bit tight. I'm intending to get hold of some more Dyeema and having another go.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #26 of 61 Old 01-31-2011
For what it's worth, having short shackles means you don't get two-blocked as quickly.. though that's not always terribly important
... or I'm wrong.
Living aboard, currently in the Chesapeake
O'Day 37, still new to us
CapTim is offline
post #27 of 61 Old 01-31-2011
AdamLein's Avatar
I was being cheap with Dyneema on my first attempt. The video uses a 36-in piece and puts marks at 12 and 17 inches, and then cut off about eight inches worth of tails and threw it away. I used 21 inches and put marks at, iirc, 7 and 11 inches.
So my lesson is that a 3/16-inch line needs 5 inches between the marks to fit the knot through the resulting loop. Could probably do with less. The position of the 12 inch mark, I think, doesn't make a difference; it just determines how much line you have to tie the knot.
My resulting shackle was quite, I thought, large. It would probably not fit in the headboard of my mainsail, but it should be fine for jib heads and clews. I would hesitate to use it on spinnaker sheets because of chafe in the pole jaws. Anyway, I'll probably get some 1/8-inch gray dyneema and try again with a smaller gap between the marks (thinking 3.25 inches).
I've heard of this issue but don't really know why it's a bad thing. Are you worried about the shackle jamming in the sheave?
AdamLein is offline
post #28 of 61 Old 02-01-2011
Nah, but if you are trying to tighten, say, a guy pole or a tack line or any handy-billy, you can't tighten things past the point where two shackles touch. So if your shackels are quite long, you might end up not being able to tension things as much as you like. It's more of a racer thing, and I'm not a racer.. but I know a lot of racer types who like to have short shackles for that reason
... or I'm wrong.
CapTim is offline
post #29 of 61 Old 03-06-2011
If you make them like the video, they are too short to fit around a pair of jib sheets. I think the ones in the video must be for replacing jib hanks where they are just going around a forestay and a bolt rope. I made a calculator for calculating the length of line and the various markers that might be of interest. It is opposite the second picture on this site Soft Shackles
Allen
allene222 is offline
post #30 of 61 Old 03-06-2011
I posted this once before on a different forum, but here it is again.This is what I use for head-sail shackles. It's permany tied in to the sheets, quick for head sail changes, and light weight.
jfurlong is offline
Cruising beginner Seanmc Cruising & Liveaboard Forum 7 09-01-2014 10:13 AM
What would you buy for $100,000? swo104 Boat Review and Purchase Forum 130 08-30-2013 11:51 AM
Crazying and Soft Spots on Deck GarrettK Gear & Maintenance 4 08-23-2004 12:57 PM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 02:15 PM
