Soft shackles a good idea? - Page 4 - SailNet Community
 1Likes
post #31 of 61 Old 03-06-2011
pdqaltair's Avatar
There is also the old low-tech version, handy for many round-the-boat tasks.
Sail Delmarva: Soft Shackles, Stropes, and Square Riggers
The real advantage of any "soft-shackle" in my expereince is that they can't scratch gel coat and don't jam like a knot.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #32 of 61 Old 03-06-2011
AdamLein's Avatar
Originally Posted by allene222 View Post
If you make them like the video, they are too short to fit around a pair of jib sheets. I think the ones in the video must be for replacing jib hanks where they are just going around a forestay and a bolt rope. I made a calculator for calculating the length of line and the various markers that might be of interest. It is opposite the second picture on this site Soft Shackles
Allen
Allen: great site, the calculator will be quite useful! Is there an easy way to change the numbers for different diameter line?
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #33 of 61 Old 03-06-2011
SailingWebGuy's Avatar
Here's a few I whipped up today.. Used Colligo's video.
My complete refit is taking completely too long!
SailingWebGuy is offline
post #34 of 61 Old 03-06-2011
AdamLein's Avatar
They look good. However Allen is correct that they're a bit small for most purposes other than maybe hanks... what do you plan to use them for?
AdamLein is offline
post #35 of 61 Old 03-06-2011
pdqaltair's Avatar
Is there any structural reason they cannot be any length?
post #36 of 61 Old 03-06-2011
tdw
Super Fuzzy Moderator
tdw's Avatar
One possible drawback of the soft shackle, if you use your spinnaker pole downwind on your headsail.
If you put eye splices into your sheets and connect them with a soft shackle they can easily become jammed in the jaws. Naturally enough this will depend on the relative size of your sheets the eye is much more likely to get caught up in the pole jaws, where a bowline creates a much larger obstruction.
I noticed this on a boat we crewed on during a few twilights this year.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #37 of 61 Old 03-06-2011
AdamLein's Avatar
Not to my knowledge... just a matter of convenience. The ones in the Colligo video come out actually quite small.
Good point. This would especially be a problem on my pole, I think, because of the shape of the jaws. I wonder if there's something one could fit over the sheet between jaws. A large wooden bead would do, but this defeats at least one of the purposes of a soft shackle if you want to use the same sheets in stronger winds without a pole.
AdamLein is offline
post #38 of 61 Old 03-06-2011
No plan on where to use them yet. Just wanted to learn how to make them. The inside diameter of the larger ones in the pic is about 1"3/4.
post #39 of 61 Old 03-06-2011
They look the perfect size to connect sheets to the clew of a jib. I'm going to order that stuff tomorrow and practice making some. Not sure where I'm going to use them, but use them I will.
genieskip
Northeast
J40
1991
genieskip is offline
post #40 of 61 Old 03-07-2011
I don't discuss my member
zz4gta's Avatar
Anyone have advice on making the stopper knot? I've looked at the video, but have a hard time picturing it when the 2 lines are parallel instead of coming at each other. Any advice?
Merit 25 # 764 "Audrey"
zz4gta is offline
Cruising beginner Seanmc Cruising & Liveaboard Forum 7 09-01-2014 10:13 AM
What would you buy for $100,000? swo104 Boat Review and Purchase Forum 130 08-30-2013 11:51 AM
Crazying and Soft Spots on Deck GarrettK Gear & Maintenance 4 08-23-2004 12:57 PM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 02:15 PM
