Soft shackles a good idea? - Page 5 - SailNet Community
 1Likes
post #41 of 61 Old 03-07-2011
tdw
Super Fuzzy Moderator
tdw's Avatar
Originally Posted by zz4gta View Post
Anyone have advice on making the stopper knot? I've looked at the video, but have a hard time picturing it when the 2 lines are parallel instead of coming at each other. Any advice?
Go over the video again. I am , I sadly admit, something of a klutz when it comes to knots and I managed to work it out. OTOH....the type of knot itself is not all that crucial. When I was originally playing around with the soft shackles I found even a simple stopper (figure of eight) will work. Just doesn't look as good.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #42 of 61 Old 03-07-2011
I don't discuss my member
zz4gta's Avatar
I did the figure eight, under load I don't see it as a problem, but rolling it around it can work lose. stuff is slippery.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #43 of 61 Old 03-07-2011
SailingWebGuy's Avatar
The knot isn't hard if you follow the video. After doing one along with the video you'll be able to tie em easily.
My complete refit is taking completely too long!
SailingWebGuy is offline
post #44 of 61 Old 03-07-2011
zz4gta's Avatar
I was looking at animated knots. Yeah, the video is a lot easier to follow. Thanks guys.
zz4gta is offline
post #45 of 61 Old 05-26-2011
Here is a page on the diamond knot Diamond Knot
And here is an animation on the knot Diamond knot animation
allene222 is offline
post #46 of 61 Old 05-27-2011
tdw
tdw's Avatar
btw .... one thing to be aware of ... you need to make sure that the shackle itself is large enough that it wont jam in something. When polling out headsail for example I've seen soft shackle jam in the pole jaws. Trap for unwary players.
― Terry Pratchett.
tdw is offline
post #47 of 61 Old 05-28-2011
AdamLein's Avatar
Good point. And the higher the load, the more likely it is to jam.
Somewhere I have seen somebody using a largish lignum vitae bead on the line (think it was an afterguy in this case0 between the shackle and the pole jaws. Probably this would for halyards as well. But where do you get such things?
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #48 of 61 Old 05-31-2011
Originally Posted by AdamLein View Post
Allen: great site, the calculator will be quite useful! Is there an easy way to change the numbers for different diameter line?
Sorry to take to long but I have finally updated the calculator to work for a few different line diameters.
Soft Shackles
post #49 of 61 Old 05-31-2011
AdamLein's Avatar
Soft Shackles
Huzzah!
By the way I used your calculator/instructions a couple weeks ago to make soft shackles for my new lifelines. The instructions were really good, as evidenced by the fact that I don't need them anymore!
AdamLein is offline
post #50 of 61 Old 05-31-2011
PaulfromNWOnt's Avatar
I've found myself wondering if line length is critical. I've made quite a few of them to pass time (non load bearing/not for marine use), and have found that I can coil the cord around to make variable loop length, then complete the splice and make the knot. If I'm using the right sized fid, then the rest is just a matter of working things in the right direction to get the desired result.
PaulfromNWOnt is offline
Cruising beginner Seanmc Cruising & Liveaboard Forum 7 09-01-2014 11:13 AM
What would you buy for $100,000? swo104 Boat Review and Purchase Forum 130 08-30-2013 12:51 PM
Crazying and Soft Spots on Deck GarrettK Gear & Maintenance 4 08-23-2004 01:57 PM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 03:15 PM
