Soft shackles a good idea? - Page 6 - SailNet Community
 1Likes
post #51 of 61 Old 05-31-2011
AdamLein's Avatar
Hey Paul. Fundamentally I don't think it is critical; assuming you have enough to do the knot on either side of the marks, only the spacing between the marks is critical. However the line in your photo looks like polypropylene to me; Dyneema's a bit pricier so ideally you don't want to waste too much of it. If you want just enough to be able to tie the knot, then the original line length is more important.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #52 of 61 Old 05-31-2011
PaulfromNWOnt's Avatar
Yes it is polyprop, costs just pennies to play around perfecting technique. As I stated, they aren't meant to be used and will never be found on my boat.
As far as I can tell, the spacing between the marks is there to determine loop size which I have done simply by forming the loop and then marking it. I wonder though, given the price of everything else we do to our boats, is an extra dollar of line going to be that detrimental?
BTW, my "fid's" bear a striking reseblance to phillips head screwdrivers.
PaulfromNWOnt is offline
post #53 of 61 Old 05-31-2011
Is there any particular reason that you can't just take a short piece of line and tie the two ends in a knot?
wordsort is offline
post #54 of 61 Old 05-31-2011
AdamLein's Avatar
I dunno. I consider myself a cost-conscious sailor, and I do hate throwing away bits of line that are too short to use. If you're making many soft shackles, it would add up... to like, $10.
Anyway I can't think of any other reason that the total line length is relevant, since you can always trim the tails at any point.
Actually, no, that's not true. If you try to use a piece of line that is too short, then you won't be able to make the shackle at all. So actually it's a minimum length of line.
AdamLein is offline
post #55 of 61 Old 05-31-2011
AdamLein's Avatar
Knots weaken the line, and the line we're talking about using here can't be easily knotted anyway. It slips.
AdamLein is offline
post #56 of 61 Old 05-31-2011
I used some to put a pair of blocks on the genoa tracks. It does slip, but I just put glue on the knot. If I need to take the blocks off I'll just cut it. As for knots weakening the line, some are better than others. It will still be stronger that the block I think.
wordsort is offline
post #57 of 61 Old 05-31-2011
Knots do indeed weaken the line, but we tend to use oversized line for ease of handling. Shackles are nice because they allow multiple use which cutting wouldn't allow.
post #58 of 61 Old 08-31-2011
zz4gta made a few from Dynema for my boat and they work great. The original strength probably goes down quite a bit compared to SS after a couple of years of use and exposure to UV. I'm guessing they would still outlast the jib sheets they are attached to...
zibadun is offline
post #59 of 61 Old 08-31-2011
tdw
Super Fuzzy Moderator
tdw's Avatar
Zibadun,
The first time I saw one of these things was on a mates boat some four or five years back. He has transferred them from his previous boat so I have no real idea how old they were at the time but by now certainly well past five years and still going string.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #60 of 61 Old 09-26-2011
I think the real advantage of using soft shackles for jib sheets is that there is no knot to hang up on the rigging. It make a huge difference in tacking with overlapping genoas.
I have a dozen articles on soft shackles, several unique varaties on L-36.com. The introductory articles is Soft Shackles
Allen
MedSailor likes this.
allene222 is offline
Cruising beginner Seanmc Cruising & Liveaboard Forum 7 09-01-2014 10:13 AM
What would you buy for $100,000? swo104 Boat Review and Purchase Forum 130 08-30-2013 11:51 AM
Crazying and Soft Spots on Deck GarrettK Gear & Maintenance 4 08-23-2004 12:57 PM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 02:15 PM
