Hull/Keel Joint Can of Worms - Page 2 - SailNet Community
post #11 of 12 Old 01-11-2008
Maine Sail's Avatar
The easiest way to tell
The easiest way to tell if you have a wood core is to drill into it with a small pilot hole. Most owners of boats are 100% clueless to this "dirty little secret" about their boats so asking other owners most likely won't get you anywhere.
Catalina offers it's customers detailed instructions on how to do this very involved repair yet perhaps only 4% of pre-1987 Catalina owners realize they have wood in their keel stub/sump. Most owners ask about fixing the keel" smile" never knowing anything about the underlying cause in most cases.
It's very rare to see post 1988 Catalina's with the "smile" unless they hit something. Catalina did NOT change this layup procedure to save money they did it to correct a problem. As these 70's & 80's boats age I suspect this problem will continually get worse...
After you drill a test hole make sure you fill it with epoxy so no more water gets into the keel stub...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 12 Old 01-11-2008 Thread Starter
Drill a Test Hole?
halekai36,
Now why didn't I think of that? I wonder how many times i have seen an article or book that has recomended drilling a hole to see what's going on...must be in the dozens, hundreds, who knows. Great idea and I will do it, but I think I will wait until #1 I get the deck work further along, and #2 warmer weather.
Again, thanks for the obvious way to answer my question!
Blessings!
SailingRandy is offline
Split deck cap and leaking hull/deck joint alaskaboy Gear & Maintenance 2 01-04-2008 09:25 PM
Hull-deck joint on Dufours MarkMiner General Discussion (sailing related) 10 01-25-2007 02:35 PM
Keel Hull joint Seekswind O'Day 9 01-09-2007 12:12 PM
Hull / Deck Joint on Pearson 303 hrmacdonald2000 Boat Review and Purchase Forum 1 03-01-2005 11:46 AM
Problematic Hull Deck Joint Dan Dickison Buying a Boat Articles 0 09-17-2001 08:00 PM
