Yanmar 3YM30 Alternator Belt - Page 2 - SailNet Community
post #11 of 14 Old 01-21-2012
Stu Jackson's Avatar
Originally Posted by sorcerer33 View Post
How can I find the Gates equivalent fan belt for my Yanmar 4JH2E? I'm going through fan belts fast because my 80 amp alternator is not aligned exactly with the belt. I need the toughest belts I can get until I can get a better alignment.
If you can still read the numbers on your existing belt, or can get them from Yanmar or a friend with the same engine, take the numbers into an auto store and they have comp charts.
If that doesn't work, take the belt off and take it with you to the auto store.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #12 of 14 Old 01-21-2012
GREETINGS EARTHLINGS . Looking at your pic. do you haVE THE CORRECT belt V section because it looks like your shredding rubber youi may need to check the sizes and compliance GO SAFE.
captflood is offline
post #13 of 14 Old 01-23-2012
Senior Moment Member
SloopJonB's Avatar
Try using cogged belts instead of conventional v-belts. They have "teeth" that make them more flexible so they can transmit power better. Might help with that small misalignment.
SloopJonB is offline
post #14 of 14 Old 01-23-2012
checked the # on my spares
For my 3ym30 I have cogged belt with the following number on it
129612-42290.
The belt for the water pump is 104511-78780
This all assumes that they gave me the right spares.
Hope this helps.
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
ereiss is offline
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 02:15 PM
Yanmar 4JH2E air filter element garyroot Gear & Maintenance 8 03-30-2010 09:23 PM
ATF or SAE ? Yanmar 4JH2E / Trans: KM4A TAK Gear & Maintenance 4 11-05-2007 11:34 PM
Yanmar with aftermarket tach and temp guage Northeaster Gear & Maintenance 12 08-07-2007 09:40 PM
Prop for Morgan OI w/ Yanmar 3GM30F cwarwick Gear & Maintenance 1 11-16-2004 02:17 PM
