01-10-2008
Non of the major players in the RV/Marine carry 12 VDC units (as far as I know), for over air HDTV converters. Naturally the Satellite system packages do... none the less... If you do end up running a inverter, it has been reported at least on some of the RV forums, don't fall for those advertised "HDTV" antennas. Regular antennas work if they are designed to pick up VHF/UHF (most HD channels are in the UHF band although a few might be found in the higher frequencies of VHF) - and most reported that using the old rabbitt ears with UHF ring, worked better than typical RV antennas....
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
