01-12-2008
Welcome to sailnet.
Ouch... I think you're going to have to drop the pan. BTW, you probably will want to contact the mods and change your handle, since posting your e-mail address like that is just asking to get spammed. Generally, I would highly recommend against using an e-mail address as a handle on any internet forum.
You might also want to read this post, which will help you get the most out of your time here on sailnet.
Originally Posted by nmerson@earthlink.net
I was attempting to change the oil in my Yanmar 3GM diesel engine with a vacuum evacuator apparatus. The plastic tubing had a piece of flexible rubber tubing, about 4 inches long, on one end. I mistakenly put this end of the tubing into the crankcase via the dipstick opening and, when I pulled it out, the piece of tubing was missing! I have used wire with a little hook on the end to try to retrieve the tubing with no success, and I cannot detect any obstruction in the opening, so I must have pushed the tubing further into the crankcase. I am afraid to start the engine with this bit of tubing still somewhere in the crankcase and I don't know what to do to get it out. Yes, I am a female and should have known better, but, I had changed the oil before many times with no problem. Can anyone help me?
