-   -   Lazy Jacks for the poor person. (http://www.sailnet.com/forums/gear-maintenance/39837-lazy-jacks-poor-person.html)
SVDistantStar 01-12-2008 08:39 PM
I want to put lazy jacks on Lola, my Bayfield 25. Now i can't afford a $200 kit from Harken so I'm going to make my own. Ive looked at a few boats that have them and they seem pretty easy to rig up myself. Ive got alot of 1/4'' line for the running line part, but I've noticed that most have wire going from the mast to the blocks. I''m just going to use my 1/4'' line tied to the blocks and the eye-straps on the mast. I bought a micro cheek block and 2 of the "key chain" blocks today. Ive got the eye straps and a small cleat already. Anything I'm missing here?
Faster 01-12-2008 08:42 PM
Ours are what looks like standard yachtbraid type line from the mast to the second split, and shock cord after that. No blocks, just eye splices.
I'm sure that you could rig what you need with what you have.
SVDistantStar 01-12-2008 08:48 PM
The setup that i looked at was on a Hunter. He said it was a Harken kit. It was a wire leader going from the eyes on the mast to small blocks. The running line started on the boom, forward starboard side went up to the block, back to the rear starboard side of the boom into an eye strap. It then went under the boom and through an eye strap than back to a block on the other wire leader. From that block it leads to the cheek block on the port side of the boom then to a small cleat just ahead of that.
Wow, i didn't think i could type all of that.
brak 01-12-2008 08:50 PM
My lazyjacks are simply 1/4" nylon braided lines with thimbled eyes on end - one line goes up the mast and back down, another from forward part of the boom up through the eye and down again and yet another from middle of the boom to the eye on second line and down to the back end of the boom.
They work ok, no worse than any other lazyjack system. However, with a fairly heavy and stiff mainsail they don't flake it nicely and only hold it somewhat. Something like "macpac" would probably work better, but that is for another lifetime.
SVDistantStar 01-12-2008 08:57 PM
Well the main on Lola is far from stiff. Its the main that came with it new. I think my idea will work ok.
sailingdog 01-12-2008 09:22 PM
1/4" line is all you really need...preferably Dacron, since it isn't as stretchy as nylon.
Valiente 01-12-2008 09:43 PM
I think your idea is fine. Just get the proportions right (google "lazy jack system" in Google: here's one: http://www.cncphotoalbum.com/doityou.../lazyjack1.htm)
and you'll be fine. Just remember to tap the boom carefully for the eyestraps and use Tufgel or something similar on the bolts, ditto for the cheekblocks.
http://www.cncphotoalbum.com/doityou...k/lazyjack.gif
SVDistantStar 01-12-2008 09:52 PM
Val,
That layout that you posted is different from what I've got in mind. I'm going to stick with what I've already got planned.
SD,
I've already got a large spool of nylon line for other projects, so I'm just going to use it. I don't think stretch is a big issue here.
mcollins07 01-12-2008 10:22 PM
I've been considering installing a Lazy Jack system also. The positioning of the lines is an issue, but not sure how critical. Some systems use blocks on the lines from the mast some, some use metal rings or even eyes with thimble. I'm also considering synthetic lines instead of wire leaders from mast. What is the advantage of wire? Looks like there are two variations: fixed leaders and adjustable lines from mast. There is more flexability with the adjustabe lines from the mast. Not sure what advantage of fixed leaders from mast?
Here are links that might be of interest:
http://www.bartonmarine.com/html/PDF...Jack%20Kit.pdf
http://www.geocities.com/opahay/ideas.htm ; click on Lazy Jack system.
http://www.boatus.com/goodoldboat/tamers.asp
- Michael
artbyjody 01-12-2008 11:31 PM
One thing to note. When I had my 'improv' lazy jack installed, it worked ok for stock dacron sail I had on my Catalina. However, once I put on my fully battened X-10 Kevlar, the battens would catch onto the lazy jack lines (going up or down) and became a major source of contention for me as I typically sail solo (and the point of the lazy jack rig was so it would bide me time and not force me to have to leave the helm to deal with it). So, if devising - have a quick disconnect system so that you can get rid of the lazy jack lines from the boom (especially handy if raising the main)...
just my experience
