01-13-2008
'72 Pearson 36
Yanmar 1GM10 cooling system, needs a good cleaning.
Ok, so the little Yanmar in Lola has been setting idle for 3 years. In my other thread for the fuel filters someone brought up the cooling system. The boat came with a bunch of spares and i did change the impeller. After changing the impeller it still wouldn't pump water out the back. I went back into it and checked the water hoses that i could remove and found them to be full of some white crud. I cleared this out and it pumps water just fine now. It doesn't over heat or have any issue, but i would like to clean the cooling system out.
What can i run through the system to clean it? The motor is raw water cooled and is in salt water. For the most part ive got real good access to the front of the motor and almost no access to the rear of the motor. I plan on installing an access hatch in the cockpit floor right above the motor.
Now what other things should i be looking at. The oil is ok since the last owner wrote on the filter when it was changed, 600hours is when it was changed and it had 611 when i got the boat, 617 now.
1972 Pearson 36 S.V. Distant Star
