01-13-2008
Ken-
Why are you looking to replace the 27 hp volvo? Also, it would help if you said what kind of boat it was. I seriously doubt that your boat will really need a 50 HP diesel, if it was originally equipped with a 27 HP engine.
Changing from a 27 hp to a 50 hp, you'll need a new transmission, new engine mounts, new prop shaft, new propellor, and a new cutlass bearing. You may also need a new water lift muffler, to accommodate the larger engine's higher exhaust output.
I would highly recommend you read this post.
