LED Replacement Bulbs? - Page 4 - SailNet Community
post #31 of 41 Old 01-17-2008
The biggest reason that you see mostly "cool" white LEDs in lighting right now is the cool white devices have a higher lumen output than the warmer light for the same size LED.
I work for a company that builds LED lighting for retail facilities and we almost exclusively use neutral white, which is in the 3750K-4300K color temp range. I have also used LEDs in the 2600K-3500K range (warm white), but the light output is not as strong as the cooler colors.
rhaley is offline
post #32 of 41 Old 01-17-2008
Will we have to get hazardous waste permits to dispose of all the mercury in all those 'green' lights mandated by the us gov?
Will we have to pay unemployment ins to all the us labor that will get laid off when the chinese made 'green' lights are mandated?
xort is offline
post #33 of 41 Old 01-17-2008
Valiente's Avatar
I would suggest that in the confines of a boat (well, most boats), it is the quality of the colour and not the intensity that make a difference. I want a strong spotlight over the sink and over the food prep counter, and maybe the best way to do that is with small halogens on some sort of gooseneck. We have 5W flourescents for reading lamps in the sea berths, 10 w halogens in the aft cabin, and undercabinet flourescents for "general area lighting" in the galley and head. Add to that a couple of incandescent wall scone lamps and a really nice Alpenglow (my favourite, actually) in the pilothouse, and it makes for a real mish-mash of types.
The role I see for LEDs (aside from nav light replacement bulbs, which I hope are made compliant in the next couple of years), is as indirect area lighting in the saloon, as "floor lighting" on companionway steps (these could be red and quite dim), as engine room lighting, and as dimmable spots for chart reading at night.
Valiente is offline
post #34 of 41 Old 01-17-2008
Valiente
In most boats, I agree completely. It is just a trend in the industry to try and make the LED fixtures brighter and cheaper, and right now, the easiest way to do that is with the cooler white colors. More bang for the buck so to speak.
The LEDs that I have set aside for my own boat are much warmer (3000K), but will require an additional LED per fixture to get the desired light level.
I should also say that I am accustomed to using the various power LEDs from the big five manufacturers, and it seems that most of the fixtures and bulb replacements (for boats at least) still use the small encapsulated style of LED. The newer power LEDs offer a lot more options and I expect to see them more and more in the better fixtures in the future.
Ryan
rhaley is offline
post #35 of 41 Old 01-18-2008
Certified Old Fart
L.E.D.'s
My thought process was to replace white bulbs behind colored lenses with white LED's, so the "color flaking off" will not be an issue. I also bought a couple of red LED's to try in some of the cabin lights for night vision reasons.
As I said before, I have not installed them yet. Will have to wait till spring.
Craig
CKDK08 is offline
post #36 of 41 Old 01-18-2008
The best route with LEDs (as has been mentioned here before) is to use colored LEDs for color applications. Not the cheap kind with a coating on the lens, but true red or green LEDs. They are more efficient, and the cost less than white LEDs. All that being said, if colored LEDs just aren't feasible for your need, the next best option is your proposal for white LEDs with a colored filter.
rhaley is offline
post #37 of 41 Old 01-18-2008
Larus Marinus
Idiens's Avatar
Just talked to a couple of colleagues who are using LED replacement bulbs in their nav lights. One is happy so far, the other has three LEDs fail in the bulb, the others working after one year. - The LEDs might have a long life, but the bit of electronics and wiring inside the bulb may not.
They recommended "wait a while" for the technology to improve and the prices to come down.
Jonathan-Livingston
Idiens is offline
post #38 of 41 Old 01-18-2008
LEDs, like other solid-state devices, only have a long life when properly fabricated and matched to the installation.
If you take a look at the LED tail lights commonly used on trucks and busses, they are a prime example of cheap LEDs. One or two dozen cheap LEDs in each unit, three or four burn out within the year but that's OK because the unit itself is still bright enough--and cheap. Using better LEDs and adding protection to the circuit would raise the cost tenfold, so cheap and sloppy wins.
OTOH the LEDs in a mercedes or Cadillac taillights supposedly raise the cost of the array to $700 factory net. They're designed to go 5-10 years without any burnouts.
Prime LEDs, properly protected, have a life near 100,000 hours. Adding protection costs more than an LED does.
Kind of like sails: They all work, some just work better and longer than others.
hellosailor is offline
post #39 of 41 Old 01-18-2008
FWIW, the "good" LEDs are units like the Lumileds Luxeon K2, which at one time was the light source for the Orca Green Marine LED nav lights. These LEDs require a constant current control and GOOD heat sinking. The constant current controller is cheap. The heat sinking is critical, as LED lifetime is directly related to the junction temperature of the LED. The major reason for the cheaper, encapsulated LEDs (the type that require several dozen to produce intense light) having a short lifetime is that they have no way of shedding heat. The premium LEDs like the ones used by OCM have a dedicated thermal connection and do a much better job of keeping the LED cool.
Absolutely.
rhaley is offline
post #40 of 41 Old 01-18-2008
General area lighting and LED's
For a long time I dreamed of being able to light up the interior of our boat and go for night after night without hurting the battery levels. I felt that LEDS were going to advance and make this possible. Unfortunately for interior area lighting they simply do not produce light in a manner that makes this possible. I can go quite a few days without recharging with the engine using a different lighting technology. BTW I have two young daughters that use lots of lights and insist on sleeping with a night light on. Any time I'm below I always seem to be turning off the lights behind them.
I hope everyone will forgive my murdering of lighting terminology. Think of a lumen as a volume of light. LED's do not produce as many lumens per watt as do compact flourescent bulbs (CFL). So for light volume per watt CFL is way more efficient than LEDS. There is another technology cold cathode ray flourescent that is even more efficient for interior lighting applications. This is what we currently use. I purchased a number of bulbs from Glenergy in Canada. They have worked well and kept me from fretting about the amps. I did kind of hurt one - cracked it's mounting base but it has been going strong with only a black tape patch. They have a one watt version that is acceptable to my daughters for night long use. An eight hour burn is only .75 amps! For general area lighting we use 5 watt bulbs and one is enough to light up the main cabin in our 30' sloop. With two on you can read anywhere in the cabin.
LED's can work well in nav lights. If you are retrofitting your fixtures, you just need to fit the most bulb possible into your old fixture. Be sure to get colored bulbs for red and green applications. Otherwise your colored lenses will stifle the light output. Your anchor light is a biggie cause you often run it from dusk to dawn. Leds make good spot lighting for task lights, etc. on the inside. And I simply will not own a non-led flashlight any longer.
Hopefully our experience will enlighten someone.
Best regards,
LH
lharmon is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Mast Head Light Freesail99 Gear & Maintenance 21 03-27-2011 09:40 PM
Anchor lights divy Gear & Maintenance 5 03-04-2007 11:54 AM
LED Replacement Bulbs Shack Gear & Maintenance 8 02-13-2007 08:10 PM
Anchor light sailor12345 Gear & Maintenance 2 07-23-2002 02:48 AM
