Old 01-18-2008
ekotopia is on a distinguished road
Aluminum diesel tank
Hi all. I am rebuilding a Morgan O/I 41. 1978 - that's been sitting for about 5 years - except for the trip from the keys to Virginia. ( and on that trip we used a day tank )
So I decided to pump out the fuel tank - about 80 gal. of fuel - and the stuff that came out was really foul. So I decided to cut a manhole and check it out. U cant belive how it looked - about 1/2 to 3/4" thick sludge stuck to the only slanted surface( about 14" at 60 degree angle the whole lenght of the tank - about 6' ) and on the bottom !!?? Nothing on the vertical areas ??
The bottom (about 6" wide ) was also covered with sludge above the suction pipe - about 1 1/2". I cleaned the tank and scraped of some hard stuff - I guess corrosion stuff -and the slanted surface and the bottom is pitted - nothing else ??!! Not the baffles or the side walls.
I poked the pits and found out that they appear to be from the inside ( they bottom out in about a 3rd of the thicknes on the slanted surface and about 1/2 on the bottom. Any ideas of why this is and how to treat the tank to be able to keep it. Is there a paint or epoxy to seal the pits with??
Cheers
Old 01-18-2008
cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough
uhhh, get a new tank. period.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
Old 01-18-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
what he said..
But if you want to be cheap about it marine-tex sticks like something nasty to wire brushed solvent free aluminum . But.. to be fair let the next owner know what you did
Old 01-18-2008
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
Glad my tank is Monel.
Old 01-18-2008
Rockter will become famous soon enough
Two part polysulphide sealant will do it. It sticks like, well, glue, and does not let go.
Old 01-18-2008
Rockter-
I don't think polysulfide sealant is a good idea in a diesel tank. Epoxy is far more fuel resistant IMHO.
Old 01-18-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
If you haven't seen this [Click Link: article before]: Probably a decent guide if you are going to do it yourself.... Although - I would consider just removing the tank and take it a machine shop in town and have them cut out the base of the tank and weld in a new one...
-- Jody
S/V "
1983, Barberis Show 38! or
Old 01-19-2008
Thanx for responds - but does any have a clue to why the sludge and pitting was only on the slanted surface . The bottom I can understand, but why not on verticals?
As of removing the tank -
only in pieces - its 120 Gal. under the side deck next to a center cockpit.
Love to hear more....
Cheers
Old 01-19-2008
Oh Saildog, thou ist contrary...
It's been on that tank for 10 years now and the water tank.
Apparently it was even rated for gasoline.
Epoxy is a bit brittle methinks and polysulphide has done it for me and still does.
I put it on with a roller after a mammoth degreasing session.
Old 01-19-2008
artbyjody's Avatar
Cheers
Its called varnishing...the diesel and whatever containments over time of non-use start a chemical reaction - since fuel evaporates - this becomes more concentrated - and the sludge contains more by products than fuel and thus the aluminum at the bottom gets attacked more ferociously.... large enough tank you may get away with the previous link suggestion I posted...
-- Jody
S/V "
Diesel Fuel Tank Woes...or Bonehead mistake of the season rperret Gear & Maintenance 9 10-07-2007 09:32 PM
aluminum diesel tank mary jewell Gear & Maintenance 2 10-05-2004 06:38 AM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Replacing the Diesel Tank Sue & Larry Gear and Maintenance Articles 0 09-18-2002 08:00 PM
Diesel Engine Woes Mark Matthews Gear and Maintenance Articles 0 09-19-2001 08:00 PM
