Updating my mainsail reefing rigging - Page 2 - SailNet Community
post #11 of 12 Old 01-19-2008
Originally Posted by lharmon View Post
My outhaul is a joke. The main has slugs that run along the boom. The block at the end is very small. I go from it up to a cleat. There is no block and tackle, nothing internal. But it’s only a 30 footer and the main is 254 ft˛. So I tighten the outhaul for strong winds and loosen it as they moderate. But I cannot re-tighten it without taking the load off the sail. I wonder what would happen if I just cut the lug off?
LH
Most outhauls need the load released on the main in order to put more tension on, esp when going upwind... unless they are hydraulic. So that in itself is not a condemnation of your setup.
The slug at the clew is important, but it may well be possible to cut off the boltrope/slugs along the foot and convert to a loosefooted main. Without the heavier slug at the clew, though, the main will tend to lift from the boom and that will reduce the effectiveness of the outhaul.
A modern day alternative to that heavy slug, esp with a loose foot main, is a double-wrap velcro strap that goes around the boom and through the clew cringle. This works well and results in much less friction on the outhaul (as does a loose foot main) It also makes it much easier to remove (unbend) the main if you need to do that.
Should you wish to go that route, the sailmaker who modifies your main can make you such a strap.
As to your reef lines, you may wish to put a light (plastic)padeye or two along the boom to keep them from sagging into the cockpit if they happen to get loose now and then.
Also cut them to length so that with stopper knots they are just slightly loose when the main is hoisted and the outhaul is eased. That will avoid unnecessary line getting in the way or flogging about and catching on cleats/heads/etc.
btw - if you ever get a new mainsail for that boat it will be difficult to really set it properly in all conditions without an outhaul that has some extra purchase, so that may be something to think about for your "wish list".
Faster is online now
post #12 of 12 Old 01-19-2008
I'd have to agree with faster that an outhaul with some leverage to it is really necessary, for instance, when you're trying to flatten the mainsail in higher winds... getting a bit more leverage makes a big difference.
BTW, I like the Dutchman Boom Brake, as I said before. I think that it is probably the easiest of the three to setup and the most cost-effective. The Wichard has to have a special line for the setup and because it has no moving parts is the least adjustable and probably the one with the most chafe. The Dutchman is adjustable in three different ways... rope diameter, rope tension and wheel tension. The Scott Boomlock is somewhat adjustable, but looks to be the most complicated IMHO to install... and is by far the most expensive.
sailingdog is offline
Standing Rigging Basics Mark Matthews Racing Articles 0 08-29-2004 08:00 PM
The Basics of Reefing Mark Matthews Learning to Sail Articles 0 03-29-2004 07:00 PM
The Basics of Reefing Mark Matthews Seamanship Articles 0 03-29-2004 07:00 PM
The Basics of Reefing Mark Matthews Gear and Maintenance Articles 0 03-29-2004 07:00 PM
The Basics of Reefing Mark Matthews Cruising Articles 0 03-29-2004 07:00 PM
