Old 01-20-2008
trantor12020's Avatar
trantor12020 is on a distinguished road
Selden Furlex 100S
Those using Selden Furlex 100S, pls tell me how tight do you tighten your headsail halyard?
Today, my friend was tighting his, using body weight and pop, up came drum assembly (lower swivel) and down goes all the lower bearings on deck and in water. It seems somewhere isn't assembled correctly. The bearing tube is secured to bearing socket and terminal eye fitting but it seems bearing tube sn't secured to the inner hub (drum assembly). Has anyone similar problem? Any solution without needing to bring down the whole forestay assembly ?
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
Old 01-20-2008
Trantor-
Your best bet would be to contact the guys at Selden. They're very good and very helpful. It sounds like whoever reassembled the furling unit last forgot to put the spring clip back in place—or put it in place but didn't make sure it was properly seated. I'm basing this on my work with the Furlex 200S on my boat.
Shouldn't have to take the forestay down to fix this BTW, and its a very good opportunity to re-grease the bearings.
Old 01-21-2008
SD, thanks for the info. There's no spring clip for th 100S but I notice a 5Dx20L mm spring pin. Will check if this is the retainer for the bearing tube for the upper portion. The lower part of bearing tube is held by 2 grub screws. Job for this weekend.
Ken
Old 01-21-2008
Ahh.. it must be very different in design from the 200s, since the top section of the furling drum is held in place by a circular spring clip in a groove. Did you try looking for a schematic of the drum from Furlex (click here)??
Old 01-23-2008
Yes, I've the Spare Part List which shows an explode view of the assembly. However, its not too apparent how the bearing tube is secured to the top of the lower swivel assembly. About the only thing that could possibly secure it would be the spring pin. I've to check it out this weekend.
Ken
Old 3 Weeks Ago
roliastoo is on a distinguished road
Re: Selden Furlex 100S
the bearing tube is secured to the top of the lower swivel assembly. To remove you need to hold the upper part of the bearing tube and then rotate the rope spool 90 degrees to unlock and then simply pull down. You may notice that there are 'flats' cast into the spool at top and bottom. Be careful of the bearings as you do so. the bearing races simply come apart and you could lose your bearing balls.
Al
Old 3 Weeks Ago
I've a question on the tack swivel though. It would appear that the swivel is 180 degrees out ie if I have a jib up in the foil with the tack attached to the swivel, wouldn't you want the jib to swivel through at least 90 degrees about the leading edge of the foil and not rotate 350 degrees about the groove end of the foil.
Old 3 Weeks Ago
I believe the manual mentioned that this is to allow the jib to tighten around the middle before the bottom start winding.
Ken
Hall vs. Selden Boom Vang? kc_cmc Gear & Maintenance 7 03-02-2010 08:49 PM
Selden Furlex question studwellboiman31 Gear & Maintenance 2 01-04-2008 05:29 PM
furlex furler Loualfr Gear & Maintenance 3 09-19-2007 11:09 PM
Furlex Furler tdw Gear & Maintenance 17 10-05-2006 09:28 PM
Selden Furlex 100S trantor12020 Gear & Maintenance 0 07-04-2006 12:08 AM
