01-23-2008
Didn't you post about this about a week or two ago???
BTW, you don't want brass for external fittings on a boat... brass dezincifies and then becomes a weak copper sponge. You want BRONZE or STAINLESS STEEL.
Plastimo makes the deck fill fittings you're looking for, but I believe they're only 1.5" not 2".
I've posted a link to the same fitting for you previously.
If you can't call Plastimo and order them directly, then my guess is you're SOL. Chances are very good that if the plastic caps are Plastimo made, the stainless or bronze ones they make will fit the same fittings.
IF you didn't call Plastimo, shut up, quit whining and call them.
