-   -   Raytheon RC420 GPS - no fix (http://www.sailnet.com/forums/gear-maintenance/40083-raytheon-rc420-gps-no-fix.html)
wduncan50 01-24-2008 10:24 AM
I have a Raytheon RC420 chart plotter that powers up but gets no GPS fix on the sats. I checked the connections on the unit to the GPS antenna and they look good. Do I need a new antenna or is there something else I need to check?
camaraderie 01-24-2008 10:45 AM
Is the ground wire ON the antenna in good shape? This should be checked as well.
wduncan50 01-24-2008 11:01 AM
The only connections I see off of the antenna are all in a single cable going to the plotter and the connection there all look good.
camaraderie 01-24-2008 11:37 AM
Well...that would hav been too easy and simple!
The 420 has a DEDICATED GPS input and cannot post a position from any other NMEA device so you will need to contact Raymarine to find an APPROPRIATE new antenna AND connector...or just get a new plotter with all the good stuff built in.
artbyjody 01-24-2008 12:08 PM
Does that model have a an ability for software upgrades and if so have you applied them? GPS satellites went through a change and during the summer of last year, most all Raymarine products had to be updated....you can get the updates if they apply by merely going to the raymarine site and register your product....
If all is connected odds are it is because the software needs to be updated...
Valiente 01-24-2008 03:54 PM
Mine was working until haulout just fine. It's currently disconnected from the antenna because the antenna is coming off with the pilothouse roof shortly.
sterndrawler 08-17-2010 09:25 AM
Raytheon Chartplotter 420 - No FIX
I had this problem and fixed it by replacing the small 'watch' battery (CR2032) in the unit.
Remove the two screws to remove the threaded base. Remove the six small screws and pry the unit apart. The battery is 'stuck' to its electrodes so use a blade and luck to get the old one out without causing damage.Hold the electrode with a needle-nose so that they don't break off.
